New Topic Post Reply  [ 1 mensaje ]
NotaPublicado: 12 Abr 2016, 14:30
hola a todos se vende le bestia... http://www.parts-express.com/Data/Defau ... 3_HR_0.jpg http://www.machinecaraudio.com/sitio/fo ... IMG516.jpg
el precio del woofer con caja a medida y reforzada es $ 24.000 .-
• Dual Composite 2-piece Cone
• Rubber Surround
• Integrated Gasket
• Cast Aluminum Basket
• Tork-Tite Terminal
• 3" 8-layer Aluminum Flat Wire Voice Coil
• FEA Optimized Motor Structure
• VMS Vented Magnet System
• Dual Progressive Spiders
• Integrated Tinsel Lead
• Nominal Impedance: Dual 2 or 4 Ohm
• Power Handling: 2000W (RMS)
Model XXX v2 12 XXX v2 15 XXX v2 18
Electrical Q Value [Qes] 0.46 0.58 0.68
Mechanical Q Value [Qms] 3.29 3.62 2.82
Total Speaker Q Volume [Qts] 0.404 0.501 0.55
Free Air Resonance [Fs], Hz 21 19.1 15.6
Equivalent Compliance [Vas], cu.ft/liters 2.61 / 74 7.61 / 207 17.02 / 482
One-way, Linear Excursion [Xmax], mm 54 54 54
Efficiency [SPL 1W/1m], dB 83.76 85.81 86.2
DC Resistance Per Coil [Re], Ohm 4.2 4.2 4.2
Nominal Impedance(dual) [Znom] 2 or 4 2 or 4 2 or 4
Thermal Power Handling [Pe], Watts 2000 2000 2000
Force Factor [Bl] 18.16 18.16 18.16
Jujuy 2983 - Whatsapp 341 3 051055 - Rosario - http://www.machinecaraudio.com
