New Topic Post Reply  [ 12 mensajes ]  Ir a página
NotaPublicado: 12 Mar 2013, 20:15
Champion
As some of you know, Hybrid Audio Technologies has been working on a new set of speakers for the H-D factory saddlebag lids. These i57-2 speakers are part of their "Imagine" series and I managed to get a set of "production-ready" speakers to install, test, and break if possible. I got them installed on Suinday and have been pounding on them ever since. All I can say is they were WELL worth the wait! I'll hit what I consider as important points in this post, then will follow-up with the install of the speakers, as well as comparing them to my JL-Audio CX-570 component set tthat I have been running for about a year. All ratings are my personal opinion, scaled from 1-5 out of 5, based on what I consider to be a pretty good ear for quality speakers. However, ALWAYS try and audition any speaker you are thinking of buying if you can.
One more caveat - as with any quality speaker, they deserve some juice to make them sing. Trying to run these 4-ohm speakers with any of the H-D factory (stock) amps will clearly limit the enjoyment of owning them. My test setup was using the rear channels of a Rockford PBR-300/4 amp, which is rated at 75w/ch at 4-ohms. This is the same amp and wiring that was used for the JL-Audio speakers in order to do a direct comparison.
INSTALLATION - 5/5
HAT really hit this one out of the park. A direct replacement for either the stock speakers on those H-D models so equipped (FLHXSE2/3, FLTRXSE. etc) - or as original speakers if you are thinking of adding the H-D factory saddlebag lids designed for speakers. ALL FACTORY MOUNTING CAN BE USED. Mount holes are a direct match, the speaker frame will cover the funky cut-out in the lid, even the factory protective baskets can be used (although they must be cut to make room for the larger magnets). The only steps required to use these speakers instead of factory speakers is to add gaskets to the HAT speakers, and cut the factory protective basket to allow for the larger HAT magnet. Keep in mind that the factory protective baskets are not required - simply obtain 4 screws and bolts of appropriate size and ditch the baskets altogether if you want. Either way, these speakers are the easiest of any speaker I've encountered to mount in the factory H-D lids. Great job to HAT on this!
SOUND - 4.8/5
These speakers sound good - REALLY good. I have been hammering them with everything I can think of and they just continue to impress. On first install, I left the JL-Audio CX570 speaker installed in the right bag so I could do an exact comparison. Keep in mind that the JL-Audio CX570 component set (MSRP $499/pr) is easily one of the best 5x7" speaker on the market, and has been proven sonically over and over again. The HAT i57-2 (MSRP $349.95/pr) is easily as good to my ears. This has been my experience across the entire HAT line - within each of their speaker lines - their speakers will perform on par with the next higher "class" of speaker. The only reason I don't rate the i57-2 a 5/5 for sound is because the JLs seemed to have a tad more bass extension (though the HATS were very close). Keep in mind that he JLs have seen some SERIOUS bass time and the HATs are brand new. Once I get 50 or so hours on the HATS I'm sure that bass extension will improve to match the JL-Audio speakers (yes - speakers need to be "broken in" to sound their best). Regardless, the fact that a $350 set of speakers can be so close in SQ to a $500 set of speakers speaks volumes (pun intended Wink ) Once the HATs break in I am sure the lower extension will be there. I could not discern much if any difference in midrange or highs between the HATs or the JLs (JL crossovers were set on flat response) - both speakers do a fantastic job of reproducing nuances in any given track without ever sounding harsh, brash, or "tinny". One of my favorite tracks to test with is Fleetwood Mac "Never Going Back Again" - the guitars on the HATs were reproduced with a very natural, warm sound - never sounding "mechanical" as some speakers can. Again - very impressed here with this $350/pr speaker.
VALUE - 5/5
This is a no brainer. Great sounding speaker even if it cost $500. Couple that with how easily these are integrated into factory HD lids, the fact that they are 4-ohm (allows easier design with aftermarket amps), are a bridged tweeter design so they won't leak, do not require external cross-overs .... the list just goes on and on an on. Anyone looking to add some serious sound quality to a Harley Bagger would do well to listen to a set of HAT i57-2 Imagine 5x7 drop-ins. They are available for pre-order now and estimated to start shipping in approximately 60 days.
Fuente:http://www.cvoharley.com/smf/index.php?topic=83018
Autor: TIF2
Bass is Easy, Balance is Hard
NotaPublicado: 12 Mar 2013, 22:44
aver te compraste una harley davidson pero le metes audio en vez de escuchar el hermoso motor que trae, es un sacrilegio como un viejito con un auto deportivo !!
NotaPublicado: 12 Mar 2013, 22:48
No entendi ja ja
HU : Kenwood x995.
Front : Hat Clarus 6".
Alpine E 12 ".
NotaPublicado: 12 Mar 2013, 23:07
Champion
pero parecería que ya trae audio original, por eso habla de los agujeros oem donde calzan perfectos los parlantes, y del ampli oem que traen la Harleys..
ademas, te quiero ver una travesía rutera, de esas que duran días, escuchando solo el motor! te cagas de embole! jajaja.
rama, probá abrirlo con el google chrome que tiene traductor de pagina, asi te lo traduce!
sino despues te hago un resumen..
NotaPublicado: 12 Mar 2013, 23:20
Muy bueno pero... no entendi nada. Ahora veo si lo traduzco en el celu no puedo.
Enviado desde mi GT-I9300 usando Tapatalk 2
FIAT PUNTO SPORTING
HU: Kenwood eXcelon KDC-X997
JL AUDIO C5-650
Rear: ???
Amp Compos: ALPINE F6
Amp Sub: Alpine M12
Sub: JL AUDIO 12W6V2
HO ported enclosure: HO112R
Wire: Stinger 4ga serie 6000 175A + RCA Stinger
NotaPublicado: 13 Mar 2013, 01:49
Champion
bueno, hago una traducción rápida:
H-D = Harley Davidson
serie imagine para Haley Davidson i57-2.
parlantes "listo para montar"
los compara directamente con unos componentes Jl cx570 que tenía montados en su H-D, que ya venía usando por aproximadamente 1 año. todo se basa en SU experiencia personal, escala 1 a 5, siendo 5 algo de buena calidad al oído.
el los jl los usaba con 2 canales de un ampli Rockford pbr-300/4, que declara 75x4 a 4 ohms.
Instalación: Puntaje 5/5
estos HAT la verdad que la pegaron. se reemplazan directamente por los parlantes stock de la H-D. que lo traen, como tanto para los que le agregan el porta parlantes original en los que no lo traen. calzan perfectos en el marco, y la reja original calza perfecta (aunque hay que cortarlo un poquito por que tiene un iman un poco más grande). cabe destacar que las rejas originales no son indispensables.. sin embargo, montar estos parlantes fue más fácil que cualquier otro que el haya probado... Felicita a HAT por esta caracteríastica..
Sonido: Puntaje 4.8/5
Los parlantes suenan bien.. MUY BIEN.. trató de darle murra a morir con todo lo que se le ocurrió, y cada vez lo impresionaba más.. al principio dejó un jl del lado izquierdo, y puso un hat del lado derecho para hacer una comparación más exacta directa. Destaca que el Jl cx570 (que tiene un valor de 499 dolares) es uno de los mejores parlantes 5x7 del mercado, y fueron probados muchas veces. a simple comparación, El HAT, con un valor de 349,95 dolares, es tan bueno como el otro. Esta es su experiencia con HAT, que los podés comparar a la par con cualquier parlante de un "escalón más alto". la razón por la que no le da un puntaje de 5/5 es que el jl tenia mas extención de bajos (aunque por muy poco). aunque también destaca que los jl ya tienen el ablande por 1 año de uso, y los HAT son nuevos todavia, y no están ablandados. calcula que para las 50 horas de uso los HAT van a mejorar mucho en esta característica. ,y tranquilamente va a igualar a los jl. destaca que el hecho de que los HAT salen 350 dolares, y esta muy cerca en cuanto a sq comparado a parlantes de 500 dolares. No pudo encontrar diferencias en los midrange ni highs entre los HAT y los JL (los cross de los jl estaban en FLAT), los 2 parlantes hacían un trabajo fantástico, sin sonar aspero, ruidoso o bajito. que siempre prueba los parlantes con un tema específico: "Fleetwood Mac - Never Going Back Again", las guitarras en los HAT sonaban muy naturales, sonido cálido, nunca sonando "Mecanico"como algunos parlantes.. nuevamente, impresionado con lo que estos parlantes de 350 dolares.
Valor: Puntaje 5/5
No hace falta ser muy inteligente.. aunque valieran 500 dolares, lo valdrían. Acompañado con lo fácil que es instalarlos, el hecho de que sean 4 ohms (más fácil para amplificar con amplis que no son OEM), que no hace falta cross-over, como estan los tweeters de manera que no se caen... la lista sigue y sigue... Cualquiera que este buscando agregar unos buenos parlantes SQ a una harley, recomienda poner estos Imagine..
NotaPublicado: 13 Mar 2013, 07:15
No creo que a él le agraden esos 5x7
Buena onda esto,ahora que leo que el tipo los comparo con unos JL,son parlantes exclusivamente diseñados para motos?O solos son 5x7 que se montan en ellas?
NotaPublicado: 13 Mar 2013, 10:06
Tienen muy linda pinta esos 5x7. Y conociendo los productos HAT, deben sonar bárbaro.
NotaPublicado: 13 Mar 2013, 12:05
Champion
Jajaja, quien te dice! x ahi le gusta escuchar Arjona mientras maneja!
Si bien son parlantes 5x7, y los podes poner en otro lugar que nosea una H-D, es un modelo diseñado para esto... Viene con tratamiento que lo vuelve resistente al agua. El modelo, según la pagina oficial de HAT, es para Harley Davidson.
NotaPublicado: 13 Mar 2013, 12:25
El 5x7 viene "optimizado" para Harley, pero lo podés poner donde se te cante
Como asi también la linea Legatia Carbon viene "optimizada" para bmw, audi y no se que otra marca de autos de alta gama, donde la profundidad de montaje es escasa, pero eso no quita que lo puedas intalar en un golcito
